Need Help Laminating ACM/Max Metal
FastMat
We are just starting to UV print on ACM/Max Metal. We have had adhesion issues and want to laminate over the print. Should we laminate then route, or route then laminate? That is my question. We are printing on digital ACM.
signheremd
Best to route the sign and then print it. If you are using a flatbed UV printer, you can print a jig (outline) of the sign on to the bed of the printer and then use that to position the routed sign. Ideally, as long as your flatbed is large enough, you would set the sign up with bleed and the jig to the same size. As far as getting the ink to adhere there are a number of adhesion promoters - like Solv S1000. You can also coat the ACM in vinyl and then print on the vinyl if need be (great way to save a piece of ACM if your printer messes up).
unclebun
Rather than trying to laminate to solve an ink adhesion problem, you should probably solve the ink adhesion problem. A building is only as good as its foundation, and in this case, the bond of the ink to the panel is the foundation. Same reason why just slapping another wrap over an old deteriorating wrap is a bad idea. When the base layer starts peeling up it takes the new layer with it.
ikarasu
If you laminate and are having ink adhesion problems, when the laminate gets heated / cooled it'll rip the UV ink off / make it crack.
You're supposed to use a UV liquid laminate like Malibu if that's your plan, otherwise within a few months it'll lookjke crap.
LarryB
We UV flatbed print on our Agfa then the ACM is laminated using our Rolls Roller. After that it goes to the router.
FastMat
That's what I was thinking as well. Do you laminate to protect the print? Are you having UV adhesion issues with the ACM?
LarryB
We use a cast overlaminate to help from fading. No issues at all with adhesion issues. Agfa ink is great.
My old HP FB500 had issues with laminate pulling up.
DL Signs
Never go against the family
This 100% ^^^^^
If you don't fix the adhesion problem, you'll always have a problem, and it's better to figure it out before you hand a customer something that'll fail. Some have good luck routing after, some don't. I always routed first, then print whenever possible. Even with good adhesion, routing puts a lot of heat and force at the cut edges that can cause ink to lift and chip, something it'll never see in use.
