Laminating - LESS IS MORE
MarkSnelling
I'm in an argument with a customer right now over a very large claim. He is burning through employees and training is a big problem.
They made 200 40x60 vinyl+lam graphics on 6mil Sintra. The graphics are "delaminating" and he is claiming it to be a material defect.
For starters, the graphics are only peeling at the lead and tail edge of the graphic. Nowhere else. Not the sides. Not the middle. And it is peeling and immediately curling up very tightly.
This is a result of too much tension on the laminating supply roll. I couldn't even make the supply roll turn with both hands due to the fact they had the tension sooo tight. I explained to him that if you were to have a rubber band and cut it so it became a rubber string (with adhesive on it)....then stretch that string and stick it to a print and let go....it will want to go back to its original state which is why only the lead and tail edges are peeling up. There was so much tension even the edges of the Sintra are barely lifting. I made the adjustments to the laminator and ran 10 boards for him and everything is perfect...no issues.
If you walk up to your laminator and it is hard to spin the supply shaft - your operator is doing it wrong. Less is more. You just don't need tension if you are running the laminator correctly. This is a really painful lesson for my customer and I've seen this happen hundreds of times. LESS IS MORE!
Random rant...but really important! If you have a shop in Chicagoland, Michigan, Ohio, or Pittsburgh and need some laminating training, reach out and if I'm in town I'll come by and fix some bad habits. I won't charge anything other than asking you to give my company a shot at earning some business. If you have a cheap off-brand laminator, you are on your own. I'll work with a Kala, Seal, old-school GBC, AGL, and GFP machines only.
Reactions: 1 users
