Im going to replace my Laminator, currently using an unsatisfying GBC 1600 with 8cm (3 [SUP]5[/SUP]/[SUB]32[/SUB] inch)
I'm intrested in either Seal 62 base or pro S. the base is 11cm (4 [SUP]21[/SUP]/[SUB]64[/SUB] inch) and the Pro S is 13 cm (5 [SUP]1[/SUP]/[SUB]8[/SUB] inch)
I had a lot of problems with my laminator (mainly, I guess, because it has preset heights of 15, 12, 10, 5, 1.5 mm, which didn't always suite the used media). I want to do face mounting on plexiglass and I have read that roller width is a major factor in the sucess of this application.
Can anyone share their wisdom on roller width and it's importance? is the difference between the base and the Pro S is important enough to shell the extra sum? Can I do successfully face mounting with the seal base?
Thank you
Ori
Thank you
Ori
