Large No Parking Signs...
Erin
Just wondering what some of you would charge for some no parking signs. There will be 2 in total that will be 24"x36" in size. I will be using white aluminum sign blanks with rounded corners (they come with the corners rounded). I will also be supplying the client with a 10' U-Channel Post for each sign. Each sign will be 2 colours vinyl (red & black) and will be basically just text.
Just wondering how much some of you would charge for these signs? I’m coming up with a price of about $145 for each sign. Does that sound about right? That doesn't include installation.
Any help would be greatly appreciated.
Checkers
I hope you're using .080" thick aluminum and I'm pretty sure you're going to need a longer post.
At a minimum, I figure 2' of the post gets burried. I ideally shoot for 3' or more on really long posts.
The other concern is that newer codes require a minimum of 80" of clearance to the bottom of the sign. So, even a 12' post may not be sufficient to properly mount the sign.
Checkers
imaSIGNr
As Checkers says....A 10 ft. post is only going to give you 5 ft. ground to bottom of sign. That might be ok for a smaller sign, but you need to be able to have clearance from anyone walking under it. I'd say you need at least a 12 footer if you'll be putting in concrete. If not then you'll need 13 ft. You can get any length you want from link I gave you in your other post. http://signs.safeshopper.com/396/cat396.htm?248
They are pricey though, plus there is a minimum order and shipping.
Go to your nearest metal shop and get some square tube stock. You'll need to prime and paint it but it'll be cheaper.
