Large routed letter pricing
Signed Out
I'm working on a quote right now for a pretty good repeat company. They have requested cut letters to mount to both sides of a large conveyor. There are large flat metal screens on the sides of the conveyor that the letters can easily be thru-bolted onto. There will be 14 letters per side for a total of 28 letters. They will be 46" tall x about 44" wide, 1/8" white ACM routed to shape, no vinyl. All the letters fit on (13) 4'x8' sheets. My substrate supplier will route and deliver the letters to me for $913. We will not be installing the letters, just delivering them about 20 minutes from the shop. I also had to go out and take measurements already which took about an hour including travel.
What would you charge for a job like this? I would normally at least double my price and add in for my time, but I feel there might be more value in something like this. I think my supplier is giving me a pretty good price on these, but don't know for sure, don't deal with too many large flat cut letters. Any input would be greatly appreciated.
Signed Out
Not that I think the markup is low, but let's say I have my own router and I was doing this in house. Material would cost roughly $650, I don't really know how long it would take to route them, but I would guess about 45 minutes per sheet figuring all the handling and programming. 13 sheets would come out to about 10 hours, plus overhead for the router... I don't know, just don't want to leave any money on the table.
Kottwitz-Graphics
Understandable.
What I would do is do a quick layout and send it to Harbor Sales and get a quote for them to do the routing. Then just add a 75% markup on it and done...
Signed Out
I would be charging around 100 bucks per letter for that type of router job.
Thank you, that is quite a bit more than my standard markup which would have been about $72 per letter. This helps to confirm that there is a little more value in a job like this. I'd rather ask for a price check on here then just slap a percentage on my suppliers quote, especially when I think I'm getting a good deal from my supplier. Anybody else have a rough per letter price??
skyhigh
The ACM 1/8" can run anywhere from $40 to $82 a sheet, depending on which product. From what you said, it looks like you're getting the better material....and a discount for quantity. Given you know the price for material ($70 something a sheet), then he is charging you $263 for the routing (under .64 a sf). Sounds like a fantastic deal to me.
I wouldn't be surprised if your supplier isn't using the $40 a sheet material, being these are going indoors. Nonetheless, you should be upcharging for both of his services (material and routing). Either way, sounds like a great price.
I see nothing wrong with your $950 mark-up. (cover the job, should you need to do them over)
ps. Your 10 hour assumption is way high. A cnc will spit each letter out in a minute. With programming, loading/unloading, cleanup...... the whole job should only take a couple hours (3.5 with a smoke break between every sheet)
