Lasering Thermal Transfer Material
asare
Hi guys,
I've been tasked with trying to apply thermal transfer material to fabrics using our laser cutter.
The theory is that with the right settings, the laser would act similar to a Thermal Transfer Printer and apply the colour to the fabric, without damaging it.
Our first attempt was simply using the ribbon from our DC5, but this did not yield good results.
Are there any materials designed for this purpose or similar?
Has anyone had any experience trying anything similar to this?
I am skeptical that this will yield nice results but wanted to see if anyone else has had success.
I am thinking it would be a better idea to simply use laser compatible Heat Transfer Vinyl
Thanks!
Ian Stewart-Koster
Older Greyer Brushie
Use laser compatible Heat Transfer Vinyl - it's polyurethane.
BUT beware the burned residue can contaminate the upper surface, and affect adhesion so after 10 washes it starts to let go.
I have essentially given up on lasering it and go back to using plotted vinyl - it's so much cleaner, and sticks better when heat-pressed on.
Or go back to screen printing it, for longevity, and no clammy feeling.
