Lighted Sign Fail (pic included)
Lucky Sky
My new customer came to me asking if we could fix this sign. The previous sign company has been sold, and the customer refuses to reach out to them and will never do business with them again. We don't do lighted signs, and he wants this repaired. It looks like they used cheap calendared vinyl that has cracked and is peeling away. It also looks like the paint on the metal is peeling. Recommendations and suggestions for how to attack this problem and prevent it from happening. I would avoid it, but this company made this type of sign all over the area, and there is a potential for more work repairing their sun-damaged signs.
Thanks in advance!
-J
Bengt Backhaus
I had a similar job.
I tried to remove it with a razorblade and that worked perfectly.
I think this was a cheap calendered aswell.
Then i just put new vinyl on it and cut the edges by hand.
I did it on site from a skylift, so it wasn't cheap but it worked well.
Sorry for the bad Google Maps picture...
DChorbowski
Pixel Pusher
I don't know if this is cheap calanderd vinyl, It just looks really old and past its lifespan tho its hard to say from the quality of the photo. Is that actually paint peeling on the trimcap or is the trimcap itself disintegrating?
We get alot of this in Florida in signs that are 8-10yrs old. The sun is just brutal and will do this to any premium cast translucent vinyl. To do it right, you will need to remove and trace and hand cut the faces and apply new vinyl and trimcap. If you are unable or unwilling in your shop to do trimcap, trace the faces on paper and provide the templates to another shop that does. Also grab some of the flaked off vinyl and also a piece of the trimcap to match their color.
  • Agree
Reactions: 1 user
JBurton
Signtologist
You would be replacing the plastic and the 'trimcap' at the same time. You have to pattern the face, either by getting a rubbing while it's still mounted, or removing and tracing onto paper or directly to the plastic. Then you jigsaw out the letter, decorate it with vinyl, and trimcap it. This is either done by pinning the edges of the letter in place with nails, then wrapping the trimcap around the face, with a nail every 1-2 inches pinning the trimcap to the plastic. You'll obviously have to remove the original nails holding the letter still when you get to them. Once the trimcap is wrapped tight, you apply glue to the perimeter. We typically use channelbond, but there are a ton of other options. We go for channelbond as it bonds to polycarbonate, which is much more forgiving, but most folks go with acrylic, which is easier to glue to the trimcap.
It is lucrative work if you are interested in expanding capabilities, but it's tedious.
  • Agree
Reactions: 1 user
