Need Help Lines when printing Magenta CJV150-130BS
pedrojt
Hello. I've been facing this issue for about 2 months, new ink and new media but it keeps printing these lines, and there are some white spots. It looks like it only happens when the image contains magenta in it, as you can see in the first image. I tried all kinds of cleaning and alignment and nothing happens. Maybe I have to change the damper? If that's the case how can I know wich one to change, since there is a damper with Magenta/Yellow, and one with Magenta/Cyan. Thanks.
note: these tests were print on bidirectional 720x1440, I've always used these settings and it wasn't bad like now.
note2: also noticed that the magenta in the test print looks thicker, don't know why.
Smoke_Jaguar
Probably dampers, could be ink starvation. On test prints the ink has a chance to catch up so to speak.
Smoke_Jaguar
Print in unidirectional mode and then unidirectional but reverse direction. If printing to the left, likely the left side one and vice versa. Setting in the Q menu in RasterLink.
pedrojt
Changed the damper and still facing the issue with magenta.
I think it's related to how the head is shooting the magenta, if you look at the magenta lines in the test print they are thicker than the other colors.
Does anyone know how can I solve this?
Smoke_Jaguar
Could be media lifting up or similar, while there is some waviness and weirdness to the magenta, slight possibility of it being an issue with the ink itself.
pedrojt
It can't be the media becouse it only happens with magenta, and also the ink has been changed mutiple times. I'm running out of ideas, i've searched through the whole forum and couldn't find anything related.
