New to this shop (sign shop at a university), it's a one man show and I'm the one (wo)-man. My experience is with Epsons, Onyx, and stand alone cutters and this Mimaki is trying every bit of patience I have. Running Rasterlink 6. I don't have any experience with print cut machines and I don't think this was the one to start that learning experience with.
Anyway on to my questions. First, comming from cutters where there is always a roll holder and baskets, how do you physically set up for long cuts? Once things slow down I will be rearranging the shop, but my predecessor bought this machine and set it up right against the wall because we have no room. So yes, I have to roll it out to change out material. I know. I also don't think anyone has mopped the floor since they put new tiles in 7 years ago. It's dragging on the floor, creasing, getting scratched, etc. Tried using the take up reel, but that didn't work. I need to be able to do long cuts since I will be doing a lot of large wall decals. 27" wide at a time. Again, I know.
Second, I'm having an issue with the actual cutting. Why so many steps just to cut? I pulled the print out so that it could outgas before cutting while I printed some other things and went back to cut it. Print is about 6 ft long. My first mistake was not realizing that you have to tell Rasterlink that you want more marks than just the corners. Noted. But it will read the two registration marks at the start of the print, the mark to the left at the end of the print and then just F's off back to the origin and says it's done cutting. Everything I've found shows short prints, nothing long.
Anyway, any help is appreciated. Reading the manual for this thing feels pointless--like yep those are words, but I don't think you used the right ones in the correct order.
