Looking for local Mimaki Tech to give estimate to repair my CVJ30 in Dallas,TX
mlathem1998
Ok, is there a tech in my area who can come look at my machine to give an estimate for repairs in Dallas, TX? I am at the end of the line with trying to get this dang thing fixed. I even had Dave, a mimaki tech who is on here from time to time on the phone stumped as to why my machine is acting like it is. For some reason I am getting an Error 205 47V Head Voltage after I replaced a ribbon cable to the head. Maybe my issue is a board now and at that point beyond my help to find out which one. I have tried a non-mimaki head, new ribbon cable, and even tried the old head and ribbon reinstalled and still no luck to clear the error 205. It seems every single time I think I will have the problem fixed I get another error or problem. So, think I need to bit the bullet, get a tech to come look at it, and just see what exactly it will take to get it fixed.
Thanks,
Error 205 means a fuse was blown. You can change the head and cables all you want but it will always give you that error until you replace the fuse. If you get a tech, make sure you get one who has the know how to test your PCBs with electronic testing equipment.
mlathem1998
I looked at the only two fuses I could find on the machine. The two fuses next to the power connection inside the panel. There is a larger clear fuse and a solid white fuse. Both look ok, so is there another fuse somewhere else on the machine, or which of the two should I just go ahead an replace?
