Looking for some feedback please...
ChiknNutz
Just wanted to check in to see where you all might be in pricing something like this. Client is a good one and has several existing aluminum panels mounted to square tubing and the panels have about 24 large dia rivets in the field of the panels, plus about 2X that many around the periphery. We will be putting full-color full-bleed prints on these, with each panel being similar, yet unique in design. In total there are 18 panels, varying from 4' x 10' to 2' x less than 10'...some being rectangle, some being triangular in shape with a total square footage of about 600. Point is, very custom job both in design and application. Oh, we'll likely travel to their location for installation about 30 miles away.
So, what I'm hoping to get is some rough estimates of what some here would charge knowing what you know.
ChiknNutz
WOW...must be so many people trying to post here that it's clogging the system. Thanks S101! You guys are the BEST!
S
Sign-Man Signs
Guest
Well here's were we start. $15.00 sq ft for printed vinyl. $40.00 an hour labor. Having to go around all those freakin' rivets...torture charge about $200.00 on top of the whole job. Lots of luck Graph
ChiknNutz
Thanks for the feedback. Ummm, anybody else? Really, I would like to get some more feedback here, no kidding, no joke. C'mon, I see a whole lot more effort put into posts about int'l teeny-bopper singers....
Letterbox Mike
Chris... I'd print on Avery MPI1005EZrs with DOL1000 laminate (assuming gloss is required). For the printing/laminating I'd come in somewhere around $8.50 p.s.f., so $5100 for the printing. For installation I'd estimate at least 3 6 hour days on site if I'm doing it myself and a helper. That's 21 hours with travel at $85 per hour... $1785 for installation. That works out to about $11.50 p.s.f. installed. In my area, that's competitive, in your area, you may be able to get another buck or two p.s.f.. Price is assuming you don't have to rent any scaffolding, ladders, lifts, etc., and that the panels are at ground lever. If you have to apply prints that big up on a ladder, I'd just pass on the job altogether, or get them to take them down and bring to your shop (or take them down yourself, outsource crane work if necessary, and do the install in your controlled environment.
Jobs like this make me nervous, outside installs are always a pain, there's always twice as much work as you originally anticipate, so charge accordingly.
ChiknNutz
Thanks...planning on Orajet 3551RA and a cast olam. Panels are at ground level and can be man-handled as needed for better installation orientation. Overall, I was right about $12 PSF. I offered up a sizeable discount to get there as they've done lots of work with us already, so I was feeling generous.
