Lowering head speed on SC30600
lainke
Hi guys,
I have my epson sc30600 for several years but must print a difficult job at the moment with lot of small text and details. I did a head alignment manualy and with block patern so my head is oke. The horizontal lines are good but but vertical are not sharp enough so i think if i can reduce my head speed it will be oke. But i can't find any setting to do this on the 30600. My previous roland could do a head speed change but could this also be done by my Epson 30600? Somebody could help?
If your vertical lines are not OK, you may want to try to adjust the feed.....there are micro adjustments that you can do to underfeed or overfeed to get rid of that. You may also want to try to see if you can try uni vs bi directional although that is not likely to help.
