Question Material See True Epoxy Floor
Guimb0
Hello I would like to have advie of wich kind of vinyl perf I should use for a logo inside a clear coat of an
Polyurethane floor.
Maybe looking for 60/40 contravision....
Thank's
I have put some graphics under ice, then we used mesh sp that the ice can go thru the tiny holes and get frosen solid, might be the same here but maybe not mesh because it is to thick, but something that is perforated to that the polyrethan can penetrate thru and make it stick better, if you use a normal sticker it might come loose when people walk on top or maybe even cars will run over it.
