Max Metal Sign Pricing
mameighan
Asked to make a 3 x 4 double sided sign with Max Metal! Simple one color vinyl layout! - Just the sign, they will install
What are your rough rates for it? Ball park figures are fine - just want to know what I would be getting into.
They want black max metal which I get for about $75 per 4x8 sheet. Will use cast vinyl.
Suggestions?
Mark
Jester1167
Charge for the whole sheet of ACM x 1.5 to 2 (that is if you get free delivery, if not add shipping or pick-up fee). Don't pro-rate it because you are aren't using the whole blank. You may or may not use the drop before it gets damaged.
Charge for the labor to cut down the sheet plus normal materials and labor for the graphics and installation.
Hard to price the sign without seeing the layout. You could have tons 1" copy which would be a lot more expensive than 3 or 4 lines of 6" copy.
$422.96 here. 100% markup on the max metal = $157.96, $25 to cut the substrate to size, $190 for the cut vinyl, $50 to apply the vinyl. Almost dead on with JHill's estimate.
