ICEdesign
Alright so im using onyx cut server with the cg 75fx. Everything used to be just fine and work great. Recently the computer took a poop and we had to reload onyx and the cut server. I noticed that onyx seems to be sending the cut file a bit too big and the plotter is cutting the graphics too far from the real "cut line"
It seems as though the plotter is reading everything ok when it checks its mark and nothing was changed on there. So I can only assume it has to do with the cut server, but not sure what to change to fix it. I am also trying to figure out which angle the plotter blade arrow should be at while cutting a 12mil polypropylene? If you are looking down at it from above, the arrow is at about a 11 o clock now.
