Myster Enigma
Hello, I recently purchased the Mimaki CJV-30-60 primarily for T Shirt Vinyls and small stickers. I bought this exactly one month after buying the Roland SP540v which was my first ever printer/cutter. It was the first time I ever had any experience with a printer cutter combo.
Now being very familiar with how the Roland functions as well as Versaworks I find the Mimaki to be a much more complex machine. With the Mimaki I can see that it is technologically superior with the print head and also the parts seem a lot more higher quality whereas the Roland looks a lot older and simplistic.
My first problem with the Mimaki starts with the pinch rollers. As this is the CJV30-60 it only has 3 pinch rollers. Each time I set the roll of media in the head scans the sheet and sometimes it will automatically move the pinch roller. Not all the time but more times than not. The photos I uploaded shows what happens. For my setting it is perfectly in the middle between the marked grid roller points. If you look at the second photo you will see that pinch roller 1 and 3 have been moved automatically slightly to the left.
Once the printer starts printing it will eventually skew and at this point only pinch roller 2 and 1 will contact the sheet whereas the third pinch roller will be rolling directly onto the grid roller. This then causes the media to jam.
Can anyone explain to me why the pinch rollers are moved automatically to the left as it's doing this for no good reason. Ideally I'd like to set it myself and keep it that way just like with the Roland.
The next question is more to do with productivity and speed. Is it normal for the Mimaki to take such a long time to begin printing? I am using Flexisign for this and once I hit the rip and print button it takes a good 2 minutes (even after the temperature is met) to begin.
I am using a CMYK set up right now, I will eventually want to go dual CMYK. At the moment is there anyway to enable Bi Directional printing? It is only printing on the left printhead pass right now.
Also does anyone recommend using a different software or is Flexisign okay.
Thank you
Thank you
