Mimaki CJV150-107 Not Printing any thing
imran aslam
Hi
I got mimaki CJV150- wide format, print head is moving, making all the moves for print command, nozzle check etc
But in reutn not printing any thing at all, not a tiny drop even.
The printer was not used for few good months and was on expired inks, I have done few good hard clean and left the print head on soak as well
Can any one please advice
dudeinthemoon
If you see ink flowing during the cleaning or filling up procedure then check encoder or it’s sensor. If not, try to pull inks through the head with syringe or push the cleaning liquid through printhead with syringe (it is more dangerous for the head). But there is a high chances that head is completely dry and you have to replace it
Impact1
Wide Format Technical Solutions
Did you leave the printer plugged in with the main power switch on so it could do automatic cleanings during the two months you weren’t using the printer?
