Mimaki JFX200-2515 print white jigs
bmaine
We want to print jigs on the bed of the printer and when we set it up to do so it doesn't give us the option of printing white. Does anyone know how to print the jigs in white?
Adam Vreeke
Knows just enough to get in a lot of trouble..
Yes, choose your color hit print. Keep the machine in local and not remote. Once job is sent over do data clear. Go to the job that it created, and in your color replacement tab change the 100% cyan or whatever you chose to 100% white.
Impact1
Wide Format Technical Solutions
Bring your jig print outline file into Rasterlink as a solid CYMK color. Then go into color replacement and replace the color you brought in to output as 100% white. If you are using the jig print function in Rasterlink I believe when you click the print option it lets you select the color you want the jig to print in.
