Question Mimaki Jv33 Capping Issue with machine off
cybershafs
Hi Guys, so replaced the capping head that came with the printhead kit from Digiprint Supplies on one of my jv33 160 printers. Adjusted the capping according to manual. everything looks fine and seals well,
However, when the machine power is turned off either at the green button or main power, the head moves slightly to the left, leaving the cap with an airgap atleast 2mm opens.
Im i using the wrong adjustments or has something else failed.
Smoke_Jaguar
Can adjust capping both mechanically and in #ADJUST menu, sounds like you need to do mechanical adjustment. The stop block on the right of the capping station might need to be adjusted or the cap might not be extending enough because of binding.
