Hi, my Mimaki JV33 won't start after I replaced the print head. When I turn the power on, the display only flashes once (very briefly) and then the machine immediately shuts down / goes into protected mode. I wanted to check/replace the fuse, but my mainboard is the version without a user-replaceable fuse. Any ideas what could be wrong? Thanks!
I've already checked all the fuses/protection elements on the mainboard with a multimeter – no open circuits, everything shows continuity.
The issue is with the voltages:
- When the machine is powered on (with the mainboard connected), the 5V rail drops to only ~2V.
- When the mainboard is disconnected and I test the power supply directly, it gives a stable 5V as it should.
