Just wanted to get a thread started about my issues, your issues or any suggestions with Mimaki UJF 3042 series printers.
First - I just purchased my second Unit only after 3 Months.
I have had a few issues so far since we have been using them - but now I am kinda invested into the machine a little to far to switch to a different brand.
First issue was adhesion problems - this wasn't a physical problem with the machine but an issue with us trying to replace products that we have been using for years with something else that would be better on this particular machine.
The second issue we have had now is either the capping station or damper issue going on right now. The Yellow and Black inks are mixing causing us to have to do 5 to 6 power cleanings before we can use the machine.
This problem has yet to be fixed - we are waiting on a tech to come out. That would lead to our 3rd issue. The support on these machines has not been the greatest. We can get people on the phone, but in our area there are no local techs and we are on a 2 week wait before we can get anything fixed.
On a good note...
The machine prints amazing - the quality is great - and overall reliability thus far has been good.
Once it gets going - you can print all day without any issues.
Keep in mind we have only been using them for about 3 to 4 months.
It was a big decision to go with these machines as opposed to the Roland LEF20 - and the LEF20 still isn't off the table - but every time i tried to use one either at a show or a Roland dealer, there has always been something wrong with it.
I have not even been able to see one print. First they told me the profiles were wrong and won't let it print - then the second time they said the machine freezes half way thru the print and says the cover is open.
I think maybe the machine is too new for me to get a good read on it.
Maintenance - There is a lot more maintenance than was mentioned prior to buying the machine. The standard capping stations need to be cleaned, around the heads, and wiping around all the areas that get overspray. But from what I am learning now (was not told during install) we need to do frequent White Maintenance - where it just pours out a ton of white ink to make sure it doesn't get clogged in the lines. Then another thing we were not told about or taught how to do is measure the inks - we had no idea when the inks get low - the machine asks you to take the inks out, weigh them, and then enter the weight in grams back into the machine. Again not a major issue - but we were never told about this.
Anyways - besides all of this - I do want to get some contacts going of people besides Mimaki and my own dealer who can help / or supply parts and or help with replacement parts if needed.
As far as warranty - any dampers or part that could be considered "consumable" have no warranty at all - our unit is only 3 months old and Mimaki told us that if the damper is the problem its not covered under warranty. I don't see Roland ever saying something like that on a machine this young. We also have a Roland XR640 - which we had some issues with - Roland sent out a tech the next day every single time and had the problem fixed at no charge.
Dealing with Mimaki warranty issues or support is seriously the biggest problem we have.
We are in South Florida and currently working with TubeLite. TubeLite seems to be great on prices - but they do not have a lot of techs that can support this machine locally.
Anyone want to share their experiences or offer any advice / tips or options for these machines?
On a good note...
