Mimaki specialist
My Mimaki printer is displaying a Error 402 MOTOR Y, and Error 50a Y origin. Any solutions on how to fix this problem? I'd really appreciate the help..
I would start with re leveling and making sure everything moves smooth.
error 402
1. Check if there is no error on the print data.(Check if the same error occurs on other data?)
2. Check if it moves to the Y-direction smoothly in thepower-off condition.
3. Check if there is no trouble on the Timing Belt.
4. Check if there is no trouble on the Motor Cable.(disconnecting, burnout, or the like)
5. Check the FFC between each PCB and Shortconnectorsconnected on the PCB.
6. Replace the Y-axis motor with a new one.
error 50a
1. Execute and confirm [#TEST]->[SENSOR TEST] ->[Y-ORG].(Confirm that the ON/OFF display isswitched by moving the carriage left and right.)
2. [Execute [#TEST]->[CHECK ENCODER].
3. Check in manual if the Head Assy. (carriage) movesleft and right smoothly.
4. Check the connector connection of Y-origin Sensorand Linear Encoder.
5. Replace the Y-origin Sensor or Linear Encoder with anew one.
6. Check the assembly and connector connection of YaxisMotor.
7. Replace the Y-axis Motor with a new one. (Refer to6.3.2)
8. Replace the Slider PCB with a new one. (Refer to6.4.5)
9. Replace the SL-Relay PCB with a new one.(Refer to 3.3.2)
10. Replace the Main PCB with a new one. (Refer to 3.3.1)
feel free to contact me with any questions, I have a Mimaki tech in AZ next week if you require service.
615-812-3001
Steve Weist
www.mimakiinkjet.com
