Mimaki UJF-6042 - Error Code: 12a Head Faild [0010]
PlanetPrinter
Hello All,
We've received the following error code on one of our Mimaki UJF-6042 printers:
ERROR 12a
Head Faild [0010]
I've contacted our dealer tech and ran through his recommended steps to try and resolve the error:
- Turn off power to machine (front panel button, and switch on back of machine)
- Un-plug machine from power outlet.
- Disconnect and re-seat ribbon cables from board in the carriage.
After those steps were completed, we fired up the machine after letting it sit for about 10 minutes. We attempted a test print; the carriage passed over the test media once, and then retracted to it's original position. The same error code appeared again.
I've also attempted to contact Mimaki tech support, but I'm still waiting for them to get back to us.
Any help with this would be greatly appreciated, as I'm beginning to rip my hair out over these printers now :banghead:.
PlanetPrinter
Update : Mimaki UJF-6042 - Error Code: 12a Head Faild [0010]
So it's been a few months since I've been actively on the boards, and I have an update to the issue that we experienced with our UJF-6042...
After much trial, error, and disassembly we found out the the printer had a faulty PCB Silder Board.
After replacing that part, we've had minimal issues with the printer, with one exception: we can never turn the power off, or we receive the same error message again. In order to fix that error message, we have to power down the machine and re-connect some of the cables that run from the PCB Slider Board to the PCS Slider Relay.
Hope this helps anyone that has similar issues with these printers!
vsdesigner
I have the same problem, did you change the PCB Slider Board yourself? If yes, do you have a video or tutorial ?? Thanks in advance.
Mrkopr
Yes! I have this issue now and was wondering if this is a tech thing or DYI . I have had the Mimaki for 7 years and have done a lot of work on it myself throughout the years. but there is no video out there or information on this process. Thank you for any information you can provide. cheers
Smoke_Jaguar
Slider PCB isn't hard to get to remove the right-hand covers, remove printhead cover, board is on top. Lots of tubing and wiring, but probably only a couple of hours of work. As with any circuit board, grounding is key to keep from exploding things.
Mrkopr
OK HERE is and WAS my problem 1st I have one of the OG 6042"s they wanted to replace everything and the head as usual. but I realized i might have got ink on my board more so where the FFC cable connects. I replaced the FFC cable removed and cleaned t my board with 97 Alcohol let it drip dry upside down and blew air until dry. i let set for a day and rehooked everything up and presto 100% again 8 years and still havent replaced a head!! that was close tho.
cheers
Mrkopr
cheers
also i found this was the problem i originaly had with missing nozzles M C
