Mimaki UJF 6042 mkiie - Reverse printing in cast acrylic setup and layers.
gitec01
hi, need help in setup printing using RasterLink. reverse/mirror printing in cast acrylic. Do you use primer to print or no? I tried the primer first, after printing the view from the other side of acrylic is blurry. But if I didn't use the primer the in ink are easily fill off. I cleaned the acrylic using isopropyl alcohol but still.
Please if you can help me. Been looking for a tutorial. Our mimaki I using LH-100 inks with CMYK WW Cl Pr.
thank you in advance
Smoke_Jaguar
Primer just wrecks printheads and alcohol is hard on acrylic, if it's laser cut, it will start to fracture when exposed to IPA.
Main thing is clean surface (wipe down with dry cloth) and give the ink a day before doing any scratch tests or anything. Had much better luck with LUS-120/LUS-150 for acrylic, but LH-100 sort of works. It has a bad tendency to crack and lift off of acrylic entirely in some instances.
Smoke_Jaguar
The PR200 series primer is literally just printing haze on acrylic, It only helps in a few circumstances, and brush-on or spray-on primers are way better and don't brick printheads. It has basically zero effect on ink adhesion for acrylic asides from negatives.
gitec01
I’d test a small piece with different layer orders and primer settings first. Too much primer or an uneven coat could affect clarity, while skipping it might explain why the ink peels off. Better to get the adhesion right on a test piece before running the full job.
Thank you will do the test and primer settings.
gitec01
Thank you for the advice.
gitec01
for the brush on or spray on any brand you suggest?
Smoke_Jaguar
Hazing is an issue with clear stuff and primer. Might have to shop around to find a good one. We just switched over to Lus-120 instead.
Nicky Zhou
PrintLinks
you can also thinking about to have some outsource primer (not inkjet, but manually wiper on it) which is for glass. or metal , those can be used for the acrylic as well. Make a super good adhesion and not effect on the clear of image .
