PA Monport 100W 40"x24" CO2 Laser Engraver Cutter Cutting Engraving Machine Rudia with Chiller $3000 OBO
trophywife
Only used a few times. Selling because we are upgrading.
Buyer must provide help to pick up. Seller is NOT responsible for moving. Contact Jill at [email protected] or call 717-433-8433 and leave message please.
Located in Newport, PA. Pick up preferred but can discuss shipping options at buyers expense.
Dimension -Working Dimension: 24” x 40” ( 60 cm x 100 cm )
-Pass-through Dimension:2.9'' x 43''(7.5cm x 109.5 cm )
-Machine Dimension: 61'' x 43'' x 35'' ( 155cm x 110cm x 90cm)
-Max Engraving Speed: 600mm/s -Max Cutting Speed: 30mm/s ( actual speed depends on material )
-Max Engraving Depth: 19.05mm -Min Engraving Depth : 0.01 mm -Focal Lens Diameter: 18mm -Mirror Diameter: 25mm
-Package Dimension: 67.6" x 48.4" x 43.7" ( 172 x 123 x 111 cm ) -7” Standard Z-depth and 8” Max Z-depth
-Net Weight: 578 lbs. (260 kg)
-Product Weight: 604 lbs (274kg) Material Capability
-Can safely engrave or cut any laser-compatible material Wood, glass, acrylic, fabric, leather, paper, cardboard, rubber
-Contact us with questions on specific materials not listed. If necessary, we can test it for you
Software -Works on Windows XP, 2000, Vista, WIN 7, 8, 10 & 11, both 64 & 32 bit -MacOS (Version 10.11 and higher) ONLY with LightBurn software
-Compatible with Lightburn, RDWorks, Coreldraw, Auto-CAD -Supported image formats: BMP, HPGL, GIF, JPG, JPEG, DXF, DST, AI and others Laser System
-Laser Wavelength 10640 nm; -Rated at over 100 watt;
-Recommended engraving speed: 100 - 500mm/s -Recommended cutting speed: 1
- 30mm/s (actual speed depends on the thickness of material) Mechanics
-Linear System -Enclosed aeronautical aluminum rails Motion -Equipped with stepper X, Y, Z axis, plus mechanical limit switches
Cooling -Chiller included Air Assist -Built-in air assist with no external compressor required Ventilation
-On-board exhaust fan, as well as an exhaust hose so you can vent the fumes to the outdoors
- Standard 110V, AC power connection
- 4-pin port connection for rotary axis devices Temperature Recommended Operating Temperature: 60-104 °F (16C-40C) Attention: the CO2 water temperature must be maintained at 60-70°F (16-21°C)
Reactions: 1 users
