Moving from an eufyMake E1 to an industrial UV flatbed: what would change?
I've been using an eufyMake E1 for a little over a month, and it's been working fine for me in terms of reliability and output quality. I've never used an industrial UV printer, though. For those who have, what differences would matter most in day-to-day production, and at what point does upgrading make sense?
Smoke_Jaguar
A drop in ink costs by about 70%+, more capacity, WAY faster printing, heads that last more than 6 months. Just think of it as going from an easy bake oven to a commercial bakery. Also really depends on model and such.
Thanks, this is helpful. Is the 6-month head life something you've seen on E1s, or is it based on XP600-class heads in general? What wears out on these heads with UV ink that lasts longer on an industrial head?
Smoke_Jaguar
They're repurposing a $60 photo printer head from Epson, the UV ink just eats them from the inside out. Epson manufactures their consumer grade junk heads in China and their commercial stuff is made elsewhere. That said, a $60 head versus a proper i3200-U1 is a difference between $60 and $900. Though, Eufy prices their stuff well into the highway robbery range.
Thanks for your insights, Smoke_Jaguar. What's your take on the HeyGears G1X and Morpho Pro, which use the i3200 head? How do they compare with industrial options?
Smoke_Jaguar
If you're going to get a cheap UV flatbed, go for a 3 head ACHI or similar. They tend to have roughly an 18"x24" bed, print way faster, no ink DRM and cheaper consumables.
That said, support is basically up to you.
dtfonestop
Smoke_Jaguar covered the cost and speed side well, so I'll add the day-to-day stuff that surprised people I know who made the same jump.
Maintenance becomes a daily habit. Most production machines circulate white ink and want a quick routine every morning and before shutdown (nozzle check, wipe, cap station), and if the shop sits cold over a long weekend you'll notice it. It's not hard, but somebody has to own it.
The workflow changes too. You'll be working in a proper RIP with white and varnish layers, and on a bigger bed the real time saver is jigs. Laying out 30 or 40 pieces at once in a cut-out template is where the throughput comes from, more than the print speed itself.
Then the room: check power (a lot of them want 220V), floor space with the loading area, and some ventilation, since you'll be running far more UV ink than on a desktop unit.
As for when to upgrade, the usual signs are the E1 running most of the day, turning away jobs because of bed size, or ink spend that's starting to look like a lease payment. When you get close, bring your own items to a demo. You can see nearby Audley dealers if you want one to compare. What kind of products are you mostly printing?
