All you need is Digitalfactory Print + Cut Production. With this program you can control more printers from a computer.Windows 7 with Flexi 19 Cloud.
Did that and didnt work...deleted them restarted PC and reloaded....boom perfect...thanks for helpYou need to set them up as 2 separate machines in production manager and then make sure you choose the correct port. One should be "USB_PRINTER_0" and the other should be "USB_PRINTER_1" As long as those ports are set properly it should distinguish between the two.
Try the demo version:
https://updater.cadlink.com/CommercialReleases/trial/DF3Trial.exe
You can easily install and remove this program.
