Question Mutoh rj900x replacement main board
place4print
Hello, I havea problem.
I saved parameters from old main board
After install new main board i see clear display.
Can you help me this problem?
I need transfer old parameters to new main board
Please help!!!
Best,
Mike
Usually you need to upload the firmware before the parameters. The firmware should be available on Mutoh's website.
Hold the left arrow key while powering on to enter board management mode. It is hard coded into the board and can run without firmware. Then you should be able to load the firmware. If you get an error about a serial number, you will have to use the board replacement wizard function in the MSA.
place4print
I try it but every time i see clear display.
if i install old main board back. its works (main board menu)
but with new. it just clear display....
The only thing I can think of is if it's an older board, you may need to transfer the memory stick from the old one to the new one. It's confusing because some require it and some don't. But if the board you are installing has a spot for a memory stick, take the one in the old board out and install it in the new one. That could be the issue. They changed these boards to be universal these days and they have built in memory but if you are installing a used or older board, it still needs a memory stick to work. The memory looks like laptop memory because that's what it is.
place4print
I know. But its new main boar. I dont see any memory slots.
henryp
If you are in MSA Technician Mode, you should see this menu. You need to use the Board Replacement Wizard. What this program does is it will clone your original mainboard.
place4print
Thank you! I will try it tomorrow morning. I send you update about the process.
Best,
Mike
TechBB
Dear,
You found MSA (Mutoh Service Assistant?
Can you help me update the firmware printer MUTOH?
I have old printer Mutoh RJ900X, I have login on Muton Club. I register printer in MSA.
But I don't have Menu on the left.
I need MSA version 4 or some other way.
Please help me.
sta25sta@gmail.com
