Question Mutoh VJ-1324 broken pinch roller holder
Hi there.
I can't see away of replacing this without pulling the whole machine apart. A major?. See attached photos. As you can see the plastic holder is broken. I tried glueing (It lasted about a week). Any tricks or thoughts much appreciated.
thanks Simon
Subysti
I don't have an answer but I have a VJ1324 you're welcome to take for parts worked fine when last it was used about 3 years ago. Switched to latex and haven't used it since. Also had mod installed to bypass ink chips. In CT. Oops. Just noticed your location.
All good. I expected you head is stuffed if it's been sitting there for 3 years. I could be interested in purchasing the head if it had been flushed out thoroughly before going in storage, but a bit of a risk. ta Simon
Subysti
It was all flushed before storage as I expected to continue using it or selling it at some point. I'm willing to give it away as who knows what may be living in it after this long. Most likely going to a recycling place soon.
bob
Hi there.
thanks Simon
Don't worry about them and someday you might want to replace them. For the nonce, if the machine is printing OK, just leave it be.
I've been running a 1204, which has the exact same pinch rollers, missing one set of 4 rollers as are you. Worse, these are the first four pinch rollers on the right. Haven't had any problems with this configuration yet. This printer is quite old and when it quits it'll be just so much junk. I won't spend much, if anything, to repair it,
Hi Bob. Thanks for the advice. I am getting some marking on the sheets where the roller is missing (I think this is called head strike? Fyi. new to signage, commercial print background). It does help if I print with the head high but this tends not to print as nice.
thanks Simon
Hi Subysti. Sounds great!. With the expense of these new it would be worth me taking a punt on it. Happy to pay for postage and a little extra for your time removing from the printer. Do you take paypal?
Feel free to email me direct. Here is my website. www.haysom.co.nz. thanks Simon
bob
thanks Simon
The only time I print with the heads down is when I forget to raise them. If one prints 'nicer' that the other you might consider diddling with whatever profile you're using. Here in my shop I only user 1 profile for everything. I used to have 2 but 1 of them went away due to lack of interest. You're printing signs, not high end art. As long as you're not dribbling ink down the front of whatever it is you're printing you're in reasonably good shape here.
Thanks Bob. I'll experiment. Someone told me the exact opposite, but I guess best just to play around and find out what works the best. ta Simon
