Update:
I went on Youtube, and search for soaking print head. Found a video, where a female technician, was able to soak the heads wthout take head assembly apart. She separted the print head carriage assembly by releasing the cutter blade.
Whole carriage assemble was now able to slide away from cap station. Next she took a
paper towel size the print station ink pad ( about 1' by 2") and soak it in eco solvent,.
Then she placed it on top of the station where the print head sits.
Next she rasied the media lever to up position.
Next she slide the print head assembly from the cap station. Had to depress the cap staton a little for a good fit by depressing it down a little with finger.
Next she is lowered the media level down.
Turn machine off if it was still on, made sure no turn it on. Let it soak (I let mine soak for 24 hours).
Next day raised media leveler. Lots of ink on
paper towel. Return the printer head carriage back to the maintence station. Next did a nozzel check all four inks were working, but not that good. Did three nozzels checks with a cleaning between checks.
Also did a ink initization both normal and little. It solved the probem with my yellow line that had air in the line. It worked. Printer now operational
Side note: I removed the assembly case to get at the the maintenace station and the one holding the inks..
Did not replace it. Just place a plastic cover over the top of both, when not in use. Allows me better access and observation
of the operaton of the printer. Hope this helps.
EZ Ink Promotions.
