Mutoh XpertJet 661UF gloss varnish overspray
Hello,
I've been having a common issue with our ADA 1% raised printing. When using this setting for out Mutoh there always seems to be a glossy overspray on the edges of the text (see photo attached). Have you ran into this issue and if so what did you do to fix it? I clean everything with alcohol before printing and use adhesive promotors when necessary but continue running into the issue.
I'm happy to provide any additional information if needed.
Thanks in advance!
-1MoreSignGuy
MahjongJoe
Never seemed to have this problem, what is your print environment settings? What materials do you print on normally? I use the ADA 1% swatch in FlexiDesign for Mutoh and export to Vertilith RIP and have a specific print environment that exclusively does the raised lettering. I only clean with alch aswell and sometimes promotor/staticide, mostly only printing and Romark.
I'm my teams Mutoh guy, I'm like 99% self taught from a sink or swim situation but I'd love to help. I've been using the 661uf for over a year now.
