Before you order the whole station, it's worth checking whether you actually need all of it. On the 1641SR a lot of "bad cap station" symptoms are really just the cap tops and wiper worn out or crusted, and those can be swapped on their own for a lot less. If the caps still have a clean, soft rim and the station lifts up fully against the heads, the problem may be the pump or a cracked suction tube instead.
If it does need the full assembly, the service manual for the 1641SR walks through it, and Mutoh's support area or your dealer can usually send the section. Go slow on the tubing and keep track of which line goes where.
After it's in, do a quick test: cap the heads, run a cleaning, and watch that ink actually pulls through the caps into the waste line. Then do a nozzle check. If you still get missing nozzles, recheck that the caps seal flat.
What's it doing right now, not sucking during cleaning or leaving the heads wet?
