Mutoh1204 banner profile using more ink?
TDFcustomSL
Ok, I know I've seen a topic on this somewhere but now I can't find it anywhere so sorry for the repeat question. I've got a couple dozen banners to print this weekend and I have been using the mutoh all in one profile for pretty much everything with good success. However, I'm needing a faster speed for printing these banners. They are for firework tents and will be seen from the road. I printed one banner using a banner 4 profile, which I believe is the fastest speed possible. But it seemed to lay down more ink than normal. My question is, do the banner 2 and banner 4 profiles use more ink? If so, what is the fastest I can print without over saturating my material? I don't want it to take a couple days for them to dry. Any help and advice will be greatly appreciated. Thanks :thumb:
FatCat
Not sure what RIP software you're using, so not what these profiles translate to in regards to resolution or number of passes. In general, higher quality profiles use more ink - a 720dpi profiles uses less ink than a 1440dpi profile. Also, more passes, uses more ink. So if you're printing banners to only be used from a distance you could go down to one of the lower resolution (540 or 360) settings and it will use less ink, print faster and still look fine from a distance. :smile:
TDFcustomSL
Sorry I forgot to include that. Im using Flexi and the settings for the banner profile are: Bidirectional, 4 pass, wave 1, 720x720
GAC05
Quit buggin' me
In the Production Manager go to the color adjustment tab and step the output (All) down from 100% to around 90% - check for color shift.
Depending on the layout there should be no noticeable change. Step it up or down until you have a good balance between ink use and color quality.
I run 4pass 720x720 at 90% (33,37,50) on gloss 13oz. banner (VJ1304) for almost all of the banners I do.
They print quickly and are dry enough to finish right off the take up reel with very little extra dry time.
Mine stay up outside just 30-60 days at a time and I have had no issues.
wayne k
guam usa
