My New Business Cards with SPOT UV
HeavyHitter
I finally got around to laying down some new cards yesterday. We have been in the new location for a month now. Sucks telling a customer you do not have a card when you design cards. LOL but I could never make my mind up on what I wanted to do.
The design is going to use "spot uv" to give it a unique look. Spot UV will make only predetermined areas of the card shine rather than the entire card coated with UV. A benefit on the rear is the ability to still write notes and quotes.
I have more of write up on the design posted here for those who would like to read more:
http://www.509media.com/business-cards/designed-a-new-509-media-business-card/
The black and white images below are the masks for the spot uv layers. The black area will receive the spot uv and shine. The white areas will be a dull finish. Because of the spot uv layers you will have to use your imagination a little to know how they will look after print. I will update the post later this week with actual pictures of the cards after print.
Rear of the cards...
J Hill Designs
I bet they will look nice! good job :thumb:
edit: have you thought of taking the "splatter" portion of 519 out of the spot uv mask?
HeavyHitter
I thought about it, but my concern was the very small detail and the process used to apply the spot uv. On a couple past projects it caused some issue. I think the final product should look very cool. I wanted the 509 to stand out. I hope the light hits it good enough to make it pop.
Thanks for the compliment.
Dan
Idea Design
Spot UV looks killer when done properly. I think you've done properly here, but i tend to agree with jhill about the 'splatter' part being taken out of the 509 on the front. Visual interest.
Nice job.
HeavyHitter
Nice job.
I am about to run a set for one of the guys here. I will give it a try on his. On mine I only ordered 1000 so I will be reordering very soon.
Dan
HeavyHitter
Just got the cards back from print. I like the end result. From one of the suggestions above we made a slight change to another set that is off to print now. I will update with the changed spot UV file once I receive them.
Dan
