Someone sent me a military crest that needs to be made into a
sign that is 6' x 6'. The file they sent is 6" at 300 dpi. I've tried upscaling it in Corel and another program but it is not good at 6'. I don't have a subscription to Topaz and am wondering if there is a way to buy "by the piece" instead of paying for a subscription. I just need this one for now. Should I but a one-month subscription and then cancel? Any suggestions? Thanks.
first check if vector artwork doesnt already exist for it somewhere else online. Do a reverse image search. If it's for a specific division you can also search google for relevant context plus "filetype pdf" and you'll find that a lot of PDFs have embedded vector logos in them.
Failing that, if the design is simple enough without gradients or textures, you should be able to image trace it into a vector. Usually helps to just upscale it as best you can as a raster image first and then let illustrator's image trace take it from there.
If you want to use a cheap AI upscaler, there's one I like to use for logos and text.
https://replicate.com/nightmareai/real-esrgan if you put like a dollar on your account you can run like 100 upscales on it or more. You can even install it locally for free if you know how. It has a limitation that it needs a starting file no bigger than 1500px by 1500px and it can do 10x scale on that. I have ocassionally broken my images into quarters when my starting image was too big. And your starting image needs to be sharp. If it's blurry you need a creative upscaler instead. This one is not creative in the slightest.
