Need Font Help
LUV DEM TIGERS
I have the worse time with Find My Font when the fonts have been compressed. And I swear it popped up but before I could get a good look at all the letters it disappeared and was not on the font choices. SCSA Palmetto 2 (002).png
LUV DEM TIGERS
Berthold Baskerville BQ OsF (Medium) is close.
Thanks. I need to start just jotting down the names of fonts when they first pop up. This isn't the first time I have had it pop one up that looked good but never showed it again. And then it will show something that doesn't even look close.
  • Agree
Reactions: 1 users
JimmyG
All of this lettering artwork has grey drop shades which makes it really hard to run thru font ID software on web online or with purchased ID software.
SignosaurusRex
The top line is a different font than the bottom two. The C and T are tell-tale and the U is completely out of element. The U has a heavier weight and appears to be a modified lower case character.
Whoever put that together was also completely out of their element. Very amateur to say the least.
  • Agree
Reactions: 1 user
Boudica
That could help. Also, study up on typography! :)
  • Hilarious!
Reactions: 1 user
Fred Weiss
All three are the same font as far as I an see ... each has been squeezed to a different degree.
SignosaurusRex
Fred, take a close look at the following aspects of the top line compared to the bottom two lines.
T ...has a Spur on both Beaks.
C ...the Terminal is shorter and does not make a complete turn upward.
A ...the Apex is wider, If the font used in the bottom two lines were to be use for the top and simply condensed, the apex would be far narrower.
  • Agree
Reactions: 1 user
