Need help printing TEST PATTERN FILL in service mode.
No Lemon
I am able to get service mode but it says "SETUP SHEET" if I press the menu button I am able to get to to the TEST PATTERN FILL but when I press enter it says"SHEET NOT LOADED, SETUP SHEET. I have vinyl loaded in the printer but cant get past this. What am I missing?
InkjetAuction
Setup Sheet
So which model are we talking about?
You should load your media, lower the pinch wheels and press the setup sheet button (if applicable) before selecting the FILL TEST menu item.
You will know that the media is properly loaded when you see the appropriately measured setup width on the display.
Only then will you be able to run any print tests.
~E
No Lemon
Sorry its a VP-540
I loaded the paper, lowered the pinch wheels. I don't have a sheet button I don't think. I have to have the printer turned off to get to service mode.
~E
FrankW
VersaCamms need to start loading manually when in Service Mode. If you have media loaded, raise the sheet loading lever and lower it again.
FrankW
could it be that you have switched off colour management? "blue to purple" sounds a little bit like that.
But you will never have best color quality without specific profiles.
Ragnabrok
CMYK from the fill pattern look normal, other than the finger prints :)
the test prints point to a head needing alignment though, notice how some colors are smooth, and others are gritty?
could be the dots are stacking on top of each other, instead of side by side. That can cause quite a color shift on its own.
post pics of service menu-print menu-head adjust-> Bias, vertical and horizontal.
may be under service menu-head adjust. print on something thin and glossy.
Ragnabrok
picture links didn't work for some reason, maybe upload to imgur?
also for fingerprints, the printer can't print to the outside 1/2" or so, so just handle the material by the edges.
Ragnabrok
outside some deflection on black, everything looks lined up. I'd guess some type of odd colour correction in the profile or color space is causing this issue.
try the same file with generic vinyl profile, and pre-press US default.
