Need help! Roland VS-640
xlvs
Need help I Bought a used Roland VS-640. I was told needed new head. When I tested It was printing but not all colors. I replaced Printhead followed all steps in service manual and now it is not printing at all. Any idea what is going on?
damonCA21
When you changed the heads, did you make sure the printer was completely powered off ( and left for at least 15 minutes unplugged from the mains ) before you removed the head cables? If not you have most likely blown the main board fuse, so that would be the first thing to check.
  • Agree
Reactions: 2 users
xlvs
I did power off and unplugged printer. I will check the fuse though. Thanks for your response.
damonCA21
Did you leave it at least 15 mins after unplugging? if not there can be some voltage left that can blow the fuse. If the fuse is ok, did you replace the head cables or use the old ones? I always replace them when I do a head change., and also did you fit new dampers?
Also, do a powerful clean on the printer, and take out the tube to the waste bottle and see if it is getting ink coming out of it. If it isn't then you know there is a problem with the physical ink supply to the heads
xlvs
Yes I did wait 15 mins after powered off printer before removing printhead. I just replaced the two mainboard fuses and still not printing.
I did not replace cables nor dampers. I will get the parts and see if that works. Thanks.
xlvs
I just ran a powerful cleaning and there is no ink flowing to the waste bottle. Why do you think thi is?
damonCA21
OK if it had been left standing not in use for a while the ink has probably dried in the ink hoses and dampers. Did you leave it for a long time not being used before fitting the new head?
Those are the first things you need to check to make sure ink is actually getting through to the heads. You also need to check the ink hose from the captop and those in the printer. They are very prone to getting clogged. The ink dries out to become a sludge and blocks them.
xlvs
Yes, I think lines are clogged Indeed yellow ink is contaminated with dark ink. I tried using a syringe to check if ink was flowing to the heads and it wasn't. I've traced it back to the chock valve it was probably closed for too long.
James Gallant
Graphic Designer
Not a guaranteed fix, but worked for my VS-300i. I inserted cleaning cartridges into all the slots and left it to sit over the weekend and it helped break it up and I was able to push it out that Monday morning and all was back up and running. Hopefully it will help.
  • Agree
Reactions: 1 user
