dylanfromwell
Hi all, this is my first post so I hope I’m doing this right.
So here is my problem: I am making decals for motocross bikes and the 2xCMYK bulk ink setup in my Roland vs640i (Versaworks RIP) limits the possibility to reach the desired colors. I would like to match KTM orange or Kawasaki Green, but they are simply way out of gamut. I already profiled everything with an i1pro2 and I use the Roland spot color library.
The newest Roland machines support green and orange ink and with these I am told the desired colors are easily reached.
Is there a way to convert my Roland to an orange and green setup? I called my local Roland dealer and they said it’s not possible. But then I found these topics below describing the usage of Epson inks in combination with the cmyk roland inks and Onyx RIP software. It looks very interesting but I don’t know where to start (who to call to do this):
www.signs101.com
www.signs101.com
Also I found this company who sells ink cartridges specially for the VSi printers, but they are incredibly expensive (€119 for 220ml!) maybe I can only use the orange and green and keep my CMYK bulk system?
www.cmaimaging.com
I hope you guys have some suggestions or tips what to do and not to do!
Cheers, Dylan
Verzonden vanaf mijn iPhone met Tapatalk
install inks, orange, green, fluor yellow and magenta fluor in roland vs540 i
hello good someone knows how to install orange, green and red inks in a roland vs 540 i. I have seen a configuration with fluorine inks. I know that Roland took out the 640 640 with those inks. but I want to know if in vs 540 i can do the same option. Attached image to see that it is true. I...
About EPSON s80600 Metallic print
Hi All , I am looking for to buy a new EPSON s80600 at Hong Kong , but I am worry for the metallic effect is not good ! I have try to contact sole agent at Hong Kong but it said no Demo unit at Hong Kong . May I ask any member who have a s80600 can help me print out some metallic swatch and...
CO-VSi Ink Kit 8 colors CMYKOGWS 220ml: CMA Colorpack Extended Gamut Ink for Roland VSi
CMA ColorPack Extended Gamut Ink for Roland VSi is an unique CMA development of a special Eco-Solvent Ink Formula for Contract Proofing and Extended Color Gamut applications. Its wide color gamut enables to print Pantone® and spot colors to the tightest dE. The ink chemistry and rheology is...
Cheers, Dylan
