Need Pricing on 52-foot Trailer
Hello to all.
What would you price two or three 52-foot trailors, two sides, with company name and logo (see attached layout)?
Appreciate your input, Benny
:thankyou:
Imakesigns
im not too sure that you have or havent had experience by your post, but you should definitely keep in mind when you do this install...rivets. that design across a 53' span is definitely going to cross entire rows of rivets as well as panel creases. high performance cast vinyl is definitely what you wanna use. make sure you have a good ladder with plastic covers or end caps so you dont ruin the side of the trailer. i bought a fairly nice garden sprayer for 20 at the local hardware stoor, i use that to spray the soap and water cleaner and a medium bristled brush to clean all the dirt. 91 percent alcohol is my final cleaner to get the squeak. cheap single ply papertowls work well. lots of em. just in case you dont have any or all of these things you will really be better off if you do...i dont know what i would charge because im too lazy to figure that out, but it would be a lot. also if youve never done this before...its gonna take twice as long as you expected. make sure you factor in the time to move the ladder and an extra set of hands.
jdb
The trailer pictured is not 53' and the length of the amount of vinyl is not going to change. You did'nt mention anything on the back. So, 2 sides only, what you see - I would bid $1,200.00 a side - $2,400.00 total. I never clean vehicles, I tell them up front that'll be 100.00 an hour, I don't wash cars, I do signs. This quote would be for a nice flat surface, minimal rivets. I usually ask to see the trailer for a firm quote, could be lots of rivets, if so the price goes up at least 100.00 per hr. Installing this should be about half an hour a side or so. Also, if they don't have the artwork on a disk ready to go of course that would have to be accounted for.
Flame
I think that was just an example of artwork, not the actual vehicle. The one he wants to do is 53' long, not the one he showed.
n20capri
Def depends on the truck (rivets, any gouges?, contours etc etc). As stated above it needs to be super clean and if your doing the cleaning it's gonna take a while. I think I'd be up near what Flame suggested. (If I was cleaning it).
Personally I'd want to be doing the cleaning (but I use to detail cars so it would be easy for me) as I'd want to make sure all grease, wax, grime etc was off...would hate to start installing to realize it was cleaned improperly by someone else.
Also as stated it's going to take longer than you think. Good luck...let us know how you make out!
Rick, I'm slow too when I saw half hour a side I was like :help: - lol
Gordy Saunders
I would suggest that you rent scaffolding when you do a truck or trailer. Ladders are a real pain in the ^%$. I rent Baker Scaffolding. I get a 3 sets
for $45.00 a week. They are 7 feet long and 6 feet high. That give you 21 feet of easy walking to do your install. It is worth every penny. Check with your Rental Supply in your area.
n20capri
Definitely a great though!! I just did a large building sign with ladders and it was a bit of a pain.
