straightedge & utility knife. Cheap, works all the time!
In that case i use 12" metal shear with piece of styrene on top so magnet would slide easy.
Pretty muchTrying to picture this, its a thin piece of styrene under the magnet sheet to keep from sticking to the base and you just slice away?
We have one of those but has a metal surface. May try laying some scrap cardboard under it and see if that helps thingsmaybe a guillotine cutter?
Ditto on the guillotine cutter, I use it all the time for mag cards
This should do ya: http://www.uscutter.com/Mondo-Trimmer
We have cut hundreds (Probably Thousands) of sheets of magnetic with rotary trimmers. The rotatrims are great, but there are other brands too.
I agree that it can be scored, then snapped clean, but that is one small extra step. If we can cut all the way through with one motion, that saves time.
I have cut many sheets by hand too, but I try to avoid that if I can anymore.
-Gene
