I would definately ask the guy more questions before you give him a price. #1 being "What kind of plywood and paint did he use?" If he used a new piece of MDO, primed and painted it properly, then you should be all set. If not (which I'm sure is the case) I would be very reluctant in doing such a job. If the surface is rough, or the paint is inferior, you just know you're going to run into problems. Even after the hassle of putting the stuff on, there is a good chance it won't last long, and you'll be the first one to blame. This customer sounds like they are trying to save a buck, and appearance and durability seem to be less of his/her concerns. If the customer used anything less than MDO, or used inferior painting practices, I would explain to them the only way you will do the job is if THEY apply the lettering. Also suggest that due to the surface, use an Intermediate vinyl, (what good is the durability of H.P. when the paint underneath will fall off before you know it?). Both of these will keep the prices down for them, you'll still make a few bucks, and most importantly will keep you in the clear.
