Now you are seeing. What you see as the artist is not always what the viewer sees. This is why you need to think outside of the box.
Eventually you will get to the point where you see something and design it. The viewer will not see it at first, but then they will. This is what you are after.
Personally this is what I would do.
In the logo, you need sharper contrast within the color. If you step back, the s & h in wash gets lost. It's hard to see. If you contrast the colors with darker and lighter tones, you will help elimate that. In addition to that, you can use the white outline to allow for more contrast too. This could be done by thickening it a little but not too much. I like the spacing of dark between the lines in the H, so thickening the white line may not work in this case. If it does not, then you could bolden the blue lines in the word.
Now as to the flow. I would try moving the logo more to the left, like you had it in the first one. then spread your bubbles out more to the right and yes, flow it down. Not so much where it looks arched or anything like that, but more subtle. This will cause a smoother flow. I'd probably make the logo a little larger yet. More contrast in your logo, should pull your eyes in that direction even though the words gift card are in red. Even if you have to make the word Van's slightly smaller to get the logo a little larger, don't be afraid to experiment. I take it you designed this logo and it's not your customers. If this is the case, take the liberty to alter it to work for you. If it is the customers logo, then you have to leave it, but you could always make suggestions to the customer.
Try those and see what happens....
Also, attach the first card you did and the last one, side by side or one on top of the other, so everyone can see including yourself and me, the difference a little critique can make.
