Need to work on Mutoh XPJ
Kelly M
Does anyone in the group know of any technicians in the South Jersey area that could help us replace a capping station and pump on an XPJ1641SR Printer. Are there any videos of how to do this?
dtfonestop
I'm not in South Jersey so I can't name a tech for you, but whoever sold you the printer (or Mutoh's own service line) usually knows which independent techs cover your area. The guys who work on Mutoh, Roland and Mimaki eco-solvent machines tend to cover a whole region, so it's worth asking around at your vinyl/ink supplier too.
If you end up doing it yourself, it's a manageable job. A few things that save headaches: try to get the cap station and pump as the matched assembly for the 1641SR so the fittings line up. Before you pull anything, take photos of every tube and connector and tag the tubes with tape, because mixing up the cap lines and the waste line is the usual mistake. Get the carriage off the station the way the manual says before unbolting it, and keep the heads covered with a damp lint-free pad while the station is out so they don't dry.
When it's back in, make sure the caps sit level and seal flat on the heads, then run a cleaning and a nozzle check. If you still get dropouts, cap height and seal are the first things to recheck.
What made you need both parts, did the pump quit or did the caps stop sealing?
