NEED URGENT HELP- how to get rid of error 0140 in roland sp540v
Sum19
I changed on eof the capasitor in the mother board and then as i put back all in and switched on the error 0140 service call appeared. what should i do?
Attila Nagy
0104 more likely. Cap does not stand for capacitor.
the output of Cap Sensor does not reach the expected value.
damonCA21
Which capacitor did you change, and how did you test it to make sure it was faulty? As Attila says it would be 0104 as the SP540V doesn't have an 0140 code.
0104 would be the captop station sensor is not giving the correct signal. This can either be the sensor or the motor.
I have them in stock if you need them,
