You can see your cut path in the job editor before you print. If you can't you need to check all the settings.Do you have the correct spot color naming set up for your cut paths?
This. I would check this first, then check which spot color names you have Cut Server set up to accept.Do you have the correct spot color naming set up for your cut paths?
yes, Cutcontour in FLEX_CUT LAYERDo you have the correct spot color naming set up for your cut paths?
CANT FIGURE OUT,
COMING FROM SUMMA GO SIGN AND RASTERLINK
CUT SERVER ONLY IMPORT IN SVG?
Yes! I want to print too, is one of the main reasons) to print the barcode, but started testing cutter , on printing having more problems… Now I'm lost. If your not printing... then why are you going through Onyx? I don't think I understand what your trying to do here.
I can't be bothered digging around, but there should be a video on onyx youtube channel showing how it's done.You really need to have someone give you a couple hour course how to use it...
Otherwise you will be here asking hundred questions and get frustrated, not to even mention that your demo license probably runs out sooner than you figure it out.
Why don't you just export the file as SVG and load it directly into CutServer?Okay I use Onyx to do cut only sometimes. What I do is import into the Rip as if I'm going to print it (should show just cut lines, no image), set cuts on, send to print but then cancel it right away. The cut file is still sent to the cut server. You can then go to the cut server, turn off automatic mark detection, and send to cut.
I do this when we have very small type because the cutter we have paired with the printer is more precise than mine.
I'll have to try this, thanks. Have never gotten the svg workflow to work and and we have the same situation where our Summa S140T cuts better than any other plotter but can't do cut only jobs.Okay I use Onyx to do cut only sometimes. What I do is import into the Rip as if I'm going to print it (should show just cut lines, no image), set cuts on, send to print but then cancel it right away. The cut file is still sent to the cut server. You can then go to the cut server, turn off automatic mark detection, and send to cut.
I'll give this another go, thanks.Onyx can be a bit funny about importing SVG files sometimes. In Illustrator we export as SVG 1.0 format which always seems to work.
Spot colours are irrelevant in the 1.0 spec, so Onyx will convert any hairlines into cut lines. I've just tested this on a multi-colored file exported to SVG 1.0 and loaded into CutServer. All lines are coming up as cut lines.
I suspect something might be happening with your SVG exports if they aren't visible in the main window in CutServer.
