New to this. TrueVis LG 540 is down. Help!
localimpact
Hey guys.
I'm 2 months in, just took over a sign business with no experience in the industry. Full send I guess.
The 3 year old Roland TrueVis LG-540 has stopped printing. Motor error 0040 every time. Even when I try test print from screen on device.
I've cleaned the encoder strip, pretty well I think, and still no dice. Carriage moves pretty smooth on track by hand and even under its own power for manual cleaning mode with no drama. But won't print.
Maybe worth mentioning - when I took over 2 months ago this printer was moved from a front office to a back area of a shop. I built a simple enclosure with plastic sheeting to protect it from the extra dust in this area and thought it was plenty protected but now I'm wondering if that's a factor? Could be coincidence, if you believe in that sort of thing.
Any advice anyone has would be greatly appreciated. My attention now is on the encoder strip reader and scan motor.
cornholio
Check if something is obstructing the head carriage movement.
The error means that the motor draws too much juice momentarily.
It could be other problems as well like motor, servo board or power supply.
If it's not obvious, better call a tech.
hybriddesign
owner Hybrid Design
What happens if you move the head to the middle of its travel and turn it on? Does it power on and slowly return to cap? If it does you might watch the capping operation. On our old machine I remember we had the station too high and it would get stuck on the capping station and give us those errors.
lenard912
Since the carriage is moving smoothly, I would not jump straight to replacing the motor. Error 0040 can be caused by the carriage getting more resistance than the machine expects, so I would check the encoder strip/reader carefully and also watch what happens when it homes and reaches the capping station.
The move into a dustier area would make me inspect the encoder sensor and surrounding area really well before spending money on a board or motor.
