Oce Arizona 360xt - RFID card initialization failed
PhilipPrinting
Hi,
We've changed an damaged ink-pump and now we get the error on our arizona.
RFID card initialization failed.
The lights under the ink pouches are flickering. This suggests that the RFID board is receiving power.
Does anyone have any idea what this could be? And how to fix?
Joseph44708
I Drink And I Know Things
Try powering down, then remove all ink pouches and move them 6 feet away, then power on and re install pouches
dtfonestop
Since the error showed up right after the pump swap, I'd start with whatever got disturbed during that job before suspecting the RFID board itself. Lights that flicker usually mean the board has power but isn't talking properly, and that's very often a connector or cable rather than a dead board.
What I'd go through, in this order:
1. Power the printer down completely, wait a minute or two, and do a full cold start. Sometimes the ink system only re-reads everything cleanly from a full boot.
2. Reseat every connector you touched or moved to get at the pump, plus the data cable between the ink station and the RFID reader board. It's easy to knock one half off while working in that area, and a loose data line gives exactly this kind of error.
3. Look for ink that dripped or spilled during the pump change, especially on the reader board, its connectors or the cable. Clean it off, let everything dry fully, and check for any corrosion on the contacts before powering back up.
4. Pull each ink pouch and reseat it firmly, making sure the tags are clean and sitting where the reader expects them. If one slot still won't read, swap two pouches between slots. If the problem follows the pouch, it's the pouch tag. If it stays with the slot, it's that reader position or its wiring.
5. Check the error log or service screen for more detail. It often tells you which slot or board failed, which narrows it down a lot.
If everything is reseated, dry and clean and it still won't initialize, then it's worth looking at the reader board or its cable as a part. Hope it turns out to be just a connector.
