Ok. I was thinking printer has no firmware and all settings was in windows registry. I am Still learning...In theory, it's not possible - firmware recognising the printer as Fujifilm's should accept only the inks supplied by Fuji. The same is for the Oce Arizona printer. Why do you want to switch to Oce inks?
Ok. Then I understand. Thanks for the clarification.Rfid board is different between FF and OCE. Manufacturer is also stored on HDD, DataRelay and SystemControl pca. If one is replaced it gets the code of the two others.
What do you need are two oce rfid pca, a backup of your registry, a registry of exact same Océ model and a data relay of exact same Oce model for some minutes
I was getting the same thoughtsOk. I was thinking printer has no firmware and all settings was in windows registry. I am Still learning...
We also have a Oce Arizona 2260XT and have ink on stock for this printer. I already use OCE ink with sticker-labeltags and disable rfid on bags. So my idea was to jump this step.
Then I got recommendation from my friend has quite good experience in printers industry and got a good product, using it for 2 years still working fine for me.Ok. I was thinking printer has no firmware and all settings was in windows registry. I am Still learning...
It isn't possible, but you can replace the printer's index in the SDS menu, so it becomes to recognize itself as an Oce or just use the chips. In this case, you have to destroy the original RFID ring on an ink bag and stick the right chip to the RFID board instead.I have a Fuji Advance printer. Same as 480gt. Is it possible to change ink-type to OCE in windows register and use OCE-ink?
It is possible to use Fujifilm inks in Canon printers or the otherway. You have to use RFID chips, which you can buy "Canon/Oce Arizona UV Flatbed RFID Ink Chips" I have seen a Canon printer which was printing with as well Canon ink as Fujifilm inksHi!
Is someone with OCE 4xx printer willing to share registerfile? So i can compare?
Best regards, Klas
The printer index: is this in the service menu is this 21-1-82 OEM Tag, which you have to changeIt isn't possible, but you can replace the printer's index in the SDS menu, so it becomes to recognize itself as an Oce or just use the chips. In this case, you have to destroy the original RFID ring on an ink bag and stick the right chip to the RFID board instead.
