Oce Arizona white head/valve location
D3D
On the 2280 with 4 white printheads I am having some consistent dropout and want to bleed the air from the heads closest to the yellow (w14 specifically). Which white valve routes to that side of the printer?
Pauly
Printrade.com.au
Bleed the ink filters first. Same procedure when you change the filers.
then via the PC, do a long purge. it'll take you though the steps. it'll go though a bit of ink, but that will remove all air if you have any.
  • Agree
Reactions: D3D
D3D
Understood. But I only want to bleed printhead 14 and 15, not 0 and 1. Its not clear to me which filter is for which side.
edcooleyar
The tubes are labeled with the printhead they belong to. Simply match the tube labels near the filter and reservoir.
  • Agree
Reactions: D3D
Pauly
Printrade.com.au
im not sure which numbers are which.
but when you open the maintenance draw (Assuming yours has one) or viewing from the RMO side.
the rows look like this
WWKCCMMY
the First row of whites is the white ink bag/filter on the left. (W)WKCCMMY
the second one is the white/varnish one. that's for the 2nd white dead W(W)KCCMMY
hope that helps
  • Agree
Reactions: D3D
